Hey guys,
I have a 2008 ZX14 that is not charging. I took the motor out to do a valve check, sealed and put back on the frame. This bike had not problems before. Now it's not charging for some reason. I put all plugs back to where they go. changed the battery, rectifier, and stator and still no charging. I rode it for 4 miles and switch the screen to the volts section and watched my voltage go from 13 to 9 until the screen started flickering got home and it shut off. to turn it on i have to jump it. I hope I didn't mess something else up bu jumping it with cables from my car. I test the rectifier and stator and they give me readings like the manual say. I don't know what else to do next. I will start it up and check the left plug on the rectifier to see if it has 50v like the manual says to see if it's the rectifier or alternator depending on the readings. I have check all plugs and still nothing. I have taken off the TRE, the turbo, the bike is stock only has a Bazzaz unit. If anyone can help I'll appreciate it. thanks Wilson
